Exchange source file .dat file
  • August 13, 2025
  • 169 views
dsotm
I need to exchange the Data File Name of a Source File Object:
I tried to do that by python code:
import zospy
zos = zospy.ZOS()
oss = zos.connect()
oss.load(‘zmx_file.zmx’)
led = oss.NCE.GetObjectAt(1)
TypeSet_LED = led.GetObjectTypeSettings(zp.constants.Editors.NCE.ObjectType.SourceFile)
TypeSet_LED.FileName1 = 'filename.dat'
I wrote that code according to section #! [e21s03_py] in example 21 of the ZOS-API Python examples
Apparently, the code does not work.
Did anyone ever manage to exchange source files via python?
Can you provide a code snippet that works?
Thanks in advance
Best answer by chaasjes
Hi ​@dsotm,
Thank you for asking this question and nice to see you’re using ZOSPy!
I checked the example code and this works for me:
import zospy as zp
zos = zp.ZOS()
oss = zos.connect("extension")
oss.new()
oss.make_nonsequential()
# Add new catalog MISC
oss.SystemData.MaterialCatalogs.AddCatalog('MISC')
# Set Wave #1 to 0.47 micron
oss.SystemData.Wavelengths.GetWavelength(1).Wavelength = 0.47
# Use lumens as the source unit
oss.SystemData.Units.SourceUnits = zp.constants.SystemData.ZemaxSourceUnits.Lumens # ZOSAPI.SystemData.ZemaxSourceUnits.Lumens
#! [e21s01_py]
#! [e21s02_py]
# Add 4 more objects
oss.NCE.AddObject()
oss.NCE.AddObject()
oss.NCE.AddObject()
oss.NCE.AddObject()
#! [e21s02_py]
#! [e21s03_py]
# Set 1st object as a Source File
Object_1 = oss.NCE.GetObjectAt(1)
Typeset_SourceFile = Object_1.GetObjectTypeSettings(zp.constants.Editors.NCE.ObjectType.SourceFile)
Typeset_SourceFile.FileName1 = 'RAYFILE_LB_T67C_100K_190608_ZEMAX.DAT'
Object_1.ChangeType(Typeset_SourceFile)
Object_1.GetObjectCell(zp.constants.Editors.NCE.ObjectColumn.Par1).IntegerValue = 5
Object_1.GetObjectCell(zp.constants.Editors.NCE.ObjectColumn.Par2).IntegerValue = 1000
Object_1.GetObjectCell(zp.constants.Editors.NCE.ObjectColumn.Par3).DoubleValue = 2.485572
Object_1.GetObjectCell(zp.constants.Editors.NCE.ObjectColumn.Par8).DoubleValue = 0.47
Object_1.GetObjectCell(zp.constants.Editors.NCE.ObjectColumn.Par9).DoubleValue = 0.47
#! [e21s03_py]
Your code seems to be missing this line:
led.ChangeType(Typeset_LED)
And the specified source file must be located in Zemax/Objects/Sources/Source Files.
Does that help?
chaasjes
  • Visible
  • August 13, 2025
Hi ​@dsotm,
import zospy as zp
zos = zp.ZOS()
oss.new()
#! [e21s01_py]
#! [e21s02_py]
oss.NCE.AddObject()
oss.NCE.AddObject()
oss.NCE.AddObject()
oss.NCE.AddObject()
#! [e21s02_py]
#! [e21s03_py]
#! [e21s03_py]
Does that help?
