NURBS dll example
  • 22 July 2019
  • 54 views
Does anyone have an example dll showing a NURBS fully defined?
Userlevel 2
Badge
I'd love to see one too but it would have to be a very simple surface because of the very large number of control parameters needed to define a NURBS surface.  For example a fairly simple NURBS surface might be defined by x5 U curves and x5 V curves with each control curve defined by x5 control points, each of which is defined by an x,y and z value.   This adds up to 150 values needed to define the surface and although Zemax could handle up to 240 terms for a dll it would still be a quite a task to set up the initial values let alone optimise them.
Andrew
Badge
I think Grid Sag uses spline to interpolate between points, so it is partially able to do what NURBS would do. For DLL code, you may want to look and the spline and Bezier DLL from the user knowledge base:
https://customers.zemax.com/os/resources/learn/knowledgebase/how-to-create-surfaces-of-revolution-via-user-defi
Thank you both for your time. I will take another look at those examples, Ray.
Even a simple NURBS example would be useful, if anyone has one.
