I want to design a reflector
  • February 5, 2021
  • 111 views
Hello Zemax users.
I want to design a reflector in the form of adhesive or tape.
There are two rectangular lenses.
The distance between the two lenses is 0.2mm or 0.4mm.
I want to use adhesive as a reflector material in the space between the lenses. (or I will use reflective tape)
The adhesive has a thickness of 0.2mm, a refractive index of 1.7, and a reflectance of 98%.
How do I set it up?
Be the first to reply!
