How to specify adjustment surface for Surface Thickness tolerancing using Python ZOS-API
  • Oct 15, 2022 6:30 PM UTC
  • 252 views
Is there a way to specify an adjustment surface relative to another surface for thickness variation. I am developing a custom script to perturb surface #1 thickness and I would like to specify surface #6 as the adjustment surface (I am not sure if calling surface #6 as compensator surface is correct)
Basically, I would like to implement the functionality of the TTHI command using ZOS-API.
TTHI command: Surface #, Adjustment Surface # (Tolerance on thickness or position in lens units, with optional adjusted)
Thanks - A
Hi @Asuku !
Setting surface 6 as the compensator is not quite the same functionality as a surface thickness adjustment, as a compensator is optimized vs a criterion. A surface thickness adjustment is just taking an extra thickness and affecting it to another surface.
I think you should be able to read the variation of the thickness, right? Then it can be applied to your surface 6 for example. We have some solves like position solves but I am not sure it is needed here.
Hi @Asuku !
  • Oct 17, 2022 3:00 PM UTC
Hi Sandrine, yes that is exactly what I would like to do. I would like to set Surface# 6 as adjustment.
So, you suggest that I manually change thickness on Surface6 based on the Δ change in Surface #1?
• A
Yes!
Ethan
  • Nov 23, 2022 3:41 AM UTC
@Asuku, did these suggestions work for you?
