Distortion data interval
  • Aug 10, 2021 9:39 AM UTC
  • 233 views
The "Y angle" interval is 0.8 (degrees), as shown in the figure below.
But I want to get the data "Y angle" interval is 0.1 (degree).
The maximum field keeps 80.0 degrees.
How can I get the data "Y angle" interval is 0.1 (degree)?
Thank you!
Anna
Best answer by Mark.Nicholson
Hey Anna,
The FC/D plot does not let you select the data interval, so if you need the data on some specific grid you’ll need to write a macro. I’d probably use the DISG operand to compute the distortion at the desired field.
  • Mark
Hey Anna,
  • Mark
  • Aug 12, 2021 10:31 AM UTC
Hi Mark,
Thank you for your answer.
I got it.
Anna
