I am trying use ‘decenter of a lens’ as a compensator in Tolerancing. For that i have made coordinate breaks before and after the lens that i want to decenter. Then used the tolerancing operand CPAR and used the first coordinate break as the surface and parameter as the x and and y decenter.
My question is will the pickup solve on the second coordinate break will cause problems when the Sensitivity based tolerancing is carried out.
Is there any other method to use element decenter as a compensator in tolerancing analsis.
Thanks in advance.
Best answer by Mark.Nicholson
