Calculate Fresnel parameters in NSC using the Merit Function
  • September 3, 2021
  • 179 views
Hello David,
To design the real Fresnel lens one needs to use “Fresnel 1” in Non-sequential mode. But I have no idea on how to calculate the following parameters for Fresnel 1 using Merit function
a)Pitch
b)Radius
c)coeff r^2, Coeffr^4 and so on.
I calculated these parameters easily in sequential mode. But in Non-sequential mode I dont know which parameter in optimization tab controls it. The below image is for reference.
Does anybody know how to calculate it?
Edit: This post has been moved into its own discussion topic. This was previously posted as a reply here: Which operand I can use to fix focal length while optimizing lens in non-sequential mode? | Zemax Community
Best answer by David
This topic was explored in a similar post here
  • 337 replies
  • September 24, 2021
designerguy13-photonics
How to calculate the sag for my Fresnel1 type lens in mixed mode simulations?
