Zemax Macro
  • 8 June 2023
  • 548 views
Hi guys,
I am new to learning ZPL. I have a list of macros that I am tasked to write at work. Here are the list below with their purpose. I was hoping anyone have written similar macro, p[lease share or give me tips on how to write them. Thanks.
  1. Compute the paraxial ABCD matrix between 2 surfaces.
  2. Bend a lens. Given one radius, compute the other radius to maintain the focal length.
  3. Macro to plot and optionally list the distortion over the full image format
  4. Calculate relative or absolute dn/dT values based on the Schott equations
  5. Draw the aperture(s) associated with a surface.
  6. Define a macro function to compute the clearance between two surfaces, including the sags of the two surfaces
  7. Compute the angular boresight error in object space of the system due to the decentration of a surface or a group of surfaces.
  8. Compute the edge thickness between two surfaces at a specified x,y location
  9. Plot the FOV points
  10. Tabulate the focal lengths of each component in the specified surface range. A component is a single surface mirror, a lens, or a cemented lens
  11. Compute the local focal length in the x and y directions over the FOV.
  12. List and plot focal length vs. wavelength or the percent change in focal length vs. wavelength
  13. Do a ghost analysis between two specified surfaces
  14. Define a macro function to compute the size of a one-bounce or two-bounce ghost image at a specified image surface.
Please share if you have any of these macros or guide me. Thank you so much
icon
Best answer by Sandrine Auriol 15 June 2023, 13:04
Userlevel 6
Badge +2
Hi @spacebaba
For number 8, have a look at those two posts:
That is quite a long list.  You will be an expert user if you complete all the tasks and understand what you did.  Good luck.
See this discussion with sample code:  https://community.zemax.com/code-exchange-10/api-python-and-matlab-interactive-extension-calculate-the-ray-transfer-abcd-matrix-for-thick-lens-1969
You might need to become an expert on this topic to truly stand by your work.  Read a bunch of textbooks on computing ABCD.
This should be a straightforward easy first-order calculation, and you should program it in ZPL.  It is good practice for you.
ZOS has this functionality built-in using the Grid Distortion analysis feature.
ZOS has this functionality built-in using INDX MFE operand and TEMP MCO operand.  Alternatively, this should be a straightforward easy calculation, and you should program it in ZPL.  It is good practice for you.
ZOS has this functionality built-in using the Footprint analysis feature.
See #8 below.
Well, this is a bit nebulously defined, because what is your reference axis?  Boresight error in ZOS is defined in image space, with the object axis being reference.  Since you want it in object space, you are really asking to flip the system and trace from image to object.  Then you can use the BSER MFE operand.  If you do not want to flip the system, then you will need to do a bit of work and raytracing and possibly optimizing to find the chief ray angle in object space that makes it come out parallel to the axis in image space.
As already noted in a prior reply, Sandrine posted two separate solutions.
ZOS has this functionality built-in using the Field Data Editor feature.
This should be a straightforward easy first-order calculation, and you should program it in ZPL.  It is good practice for you, especially if you have done Task #10 above.
ZOS has nearly this functionality built-in using the Chromatic Focal Shift analysis feature.  If you absolutely need to have the actual EFL, you will need to program it in ZPL.  It is good practice for you.
ZOS has this functionality built-in using the Ghost Focus Generator analysis feature.
ZOS has nearly this functionality built-in using the Ghost Focus Generator analysis feature.  If you need to customize the results, you will need to program it in ZPL.  You will need to do both forward and backward ray tracing using the paraxial raytracing equations.  It is good practice for you.  Oh, you want to optimize on it as a macro operand in the MFE.  Yes, you will need to make your own.  Here are two examples of a single bounce and double bounce ZPL.  To debug either, put in print statements all over and run it interactively, rather than as an MFE macro operand:
!zpl18.zpl
!single bounce ghost constraint macro for optimizing a problem surface
!g nadorff  28-jun-2015
paraxial on
! passed values:
! pvhx() == beam diameter entering system
! pvhy() == start forward raytrace at this surface
! pvpx() == reflection surface
! pvpy() == end surface to eval
!trace marginal ray:
!   RAYTRACEX x, y,        z, l, m, n, surf,   wavelength
    raytracex 0, pvhx()/2, 0, 0, 0, 1, pvhy(), 1
    s = pvpx()
    eval = pvpy()
    y = rayy(s)
!   reflect off s:
    u = -raym(s-1)/rayn(s-1)-2*y*curv(s)
!   trace backwards:
    for r = s-1, eval, -1
        y = y-thic(r)*u
        u = indx(r)/indx(r-1)*u + y*(indx(r)-indx(r-1))/indx(r-1)*curv(r)
    next
!   spot diam:
    optreturn 0 = 2*y
!   pim location after eval surface:
    optreturn 1 = y/u
!print 2*y, y/u
paraxial off
!zpl17.zpl
!double bounce ghost constraint macro for optimizing
!constraint is to achieve RMS dia/airy dia ratio > 50 after paraxial lens
!call it f = 100 mm
!Hx = first reflection surface i
!Hy = second reflection surface j
!Px = final desired surface k
!Py = unused
!g nadorff  7-jan-03
paraxial on
!trace marginal ray for entire system:
 raytrace 0, 0, 0, 1, 1
i = pvhx()
j = pvhy()
k = pvpx()
!   reflect off i:
    y = rayy(i)
    u = -raym(i-1)/rayn(i-1)-2*y*curv(i)
!   trace backwards from surf i to surf j+1:
    if ((i-j)==1)
       goto 1
    endif
    for s = i-1, j+1, -1
        y = y-thic(s)*u
        u = indx(s)/indx(s-1)*u + y*(indx(s)-indx(s-1))/indx(s-1)*curv(s)
    next
label 1
!   reflect off surface j
    y = y - thic(j)*u
    u = -u-2*y*curv(j)
!   trace forward to rest of surfaces
    for s = j+1, k, 1
        y = y+thic(s-1)*u
        u = indx(s-1)/indx(s)*u + y*(indx(s-1)-indx(s))/indx(s)*curv(s)
!        focus = -y/u
!        optreturn s = abso(focus)
!        optreturn s+20 = abso(y)
    next
!   trace thru paraxial perfect lens f=100 mm:
    u = u - y/100
    y = y+100*u
    optreturn 1 = abso(y)
paraxial off
Thank you. I have written the ZPL for 1,2,3,4,6,8,10,11,12. Some of the ones you replied to as ZOS has a built-in function, I know that, but what I want to do is write a macro that does same thing as those built in functionality in ZOS. Thanks for your help!
wonderful!
