saving txt files in a loop with incremental file name
  • September 20, 2023
  • 248 views
Hi
I would like to save a txt file at each step of a loop. So I need to change the name of the saved file to not overwrite the previous one.
Does someone have an example to share?
Thank you.
Best answer by yuan.chen
How to open consecutively-named lens files using a ZPL macro – Knowledgebase (zemax.com)
yuan.chen
  • Visible
Thank you Yuan :-)
