How to read field data using ZPL Macro
  • Aug 11, 2021 3:39 AM UTC
  • 926 views
yuan.chen
For data that require only one parameter, we can use SYPR().
To extract field data, the solution is to use the numeric functions and a loop to extract data. Here are related numeric functions.
To read the number of fields or the maximum value, you can use the below funcions to read them:
