Export total power value from objects as a detector
  • September 19, 2022
  • 726 views
Carmen Lago
Hi!
I desgined a great 3D matrix of spheres as a detector.
I would like to know how to export the total power value of each detector in a single file (all the values) with a ZPL macro.
Thanks, Carmen
Hi Carmen,
Here is a simple example with 2 spheres (attached to my reply):
The code is as follows:
# Clear all detectors
clear = NSDD(1, 0, 0, 0)
# Run a raytrace
NSTR 1, 0, 0, 0, 0, 1, 0
# Read power of all objects between the first and last
# object (defined below)
# First object
first_object = 2
# Last object
last_object = 3
# Specify PRINT output file
OUTPUT "test.txt"
# Loop over the detectors
FOR object, first_object, last_object, 1
# Record total flux of current object
flux = NSDD(1, object, 0, 0)
# Print flux to file specified by OUTPUT
PRINT flux
NEXT
Please note the following about the OUTPUT keyword:
If a valid filename is provided, then subsequent PRINT commands will output to the filename specified. If a filename with no path is provided, output will be directed to the <data>\Macros folder.
The result gives the following values:
0.1954
0.8046
And these are the text tab of the detector viewers:
Sphere 2, NSCG Surface 1:
Number of pixels: 4512, Total Hits = 19543
Peak Power : 1.0460E-02 Watts
Total Power : 1.9543E-01 Watts
Sphere 3, NSCG Surface 1:
Number of pixels: 4512, Total Hits = 80457
Peak Power : 1.0500E-02 Watts
Total Power : 8.0457E-01 Watts
Let me know if you have any other question.
  • September 20, 2022
Hi Carmen,
# Run a raytrace
# First object
first_object = 2
# Last object
last_object = 3
OUTPUT "test.txt"
PRINT flux
NEXT
0.1954
0.8046
Carmen Lago
  • September 22, 2022
It works! Thanks David
Take care too
Carmen
