EFNO gives different result to that calclated in relative illumination analysis
  • Aug 23, 2021 1:26 PM UTC
  • 330 views
I have a system with a non-circular aperture and therefore try to calculate its effective f number using the operand EFNO(effective f number). However, I get different results when using the operand EFNO, in comparison to the result given in the relative illumination analysis, despite the same setting is applied on both calculation.
(wavelength 3 is 0.555µm, and field 1 corresponds to 0 y field)
As can be seen above, one gives a value of 4.13(EFNO), while the other gives a value of 3.85. I think the latter one should be correct, but the question is why does one get different results here, do these two use different algorithms for calculation? How can I calculate this value in a Zemax macro conveniently if the result provided by EFNO is not trustworthy….
Thanks a lot in advance!
Best answer by Nicolò.Bassoli
Hi!
I don’t know if it’s too late, but I noticed that based on the selected sampling in the EFNO operand, the results can vary greatly.
For example:
While the relative illumination plot give as EFNO a value of 1.604542.
The sampling of relative illumination is about 20
somehow the images are not showing up correctly… these are what I was referring to in the quesiton.
Hi!
For example:
