Creating CAD objects from “Voxel Maker.ZPL” macro
elisenda v.
Hello everyone,
I tried to use the “Voxel Maker.ZPL” macro provided in the following article: How to show Detector Volume data in 3-D, but even though no errors appear, it doesn’t create any imported CAD. Is there any new version I can use?
Thank you!
@elisenda v.
Its hard to troubleshoot such a complex macro without looking at your file. My educated guess would be to look at line 144 of the macro:
data = 1  # set this equal to 1 in order to show ABSORBED flux data
Depending on how you’ve setup your Detector Volume, this data (from the NSDD numeric function) could amount to nothing. Can you try with data = 0 instead?
My feeling is that it would be worth implementing this macro with the ZOS-API as it is easier to troubleshoot more complex code in an integrated development environment (IDE).
Hope this helps and take care,
  • 1141 replies
  • March 25, 2024
@elisenda v.
Kevin Scales
  • 185 replies
  • April 18, 2024
David is correct. Without a sample, there’s no good way to answer this except by guessing. The sample worked the last time I worked with it, so I’m guessing it is something like what David suggested (which is on line 114, not 144) or possibly a path issue.
Yes, the line is 114. Thanks for correcting me @Kevin Scales.
