Converting sequential surfaces to non-sequential objects: ZPL command
  • Sep 5, 2021 1:59 PM UTC
  • 395 views
bhousand
All,
What is the ZPL command to execute the ‘Convert to NSC Group’ function available via the GUI? I want to convert and save many (Monte Carlo) files in a loop.
Hi Bhousand,
I don’t think that there is such a feature in the ZPL langage. Others can correct me if I’m wrong.
You’d have to use the ZOS-API for this task, which can open the Convert to NSC tool. The ZOS-API Syntax Help has an example, example 14, which shows exactly how to do that. The excerpt from that help file reads:
    # Convert file to Non-sequential mode
    convertNSmode = TheSystem.Tools.OpenConvertToNSCGroup()
    convertNSmode.ConvertFileToNSC = True
    convertNSmode.RunAndWaitForCompletion()
    convertNSmode.Close();
    # Save the Non-sequential file to the Double Gauss folder
    fileNameNS = dirLoc + "\\Double Gauss (NS).zmx"
    TheSystem.SaveAs(fileNameNS)
Let me know if this helps.
  • Sep 6, 2021 9:55 AM UTC
Hi Bhousand,
