Commenting Blocks of ZPL Code at Once
  • Aug 17, 2020 9:28 PM UTC
  • 475 views
Hello!
Is there a shortcut to be able to comment out entire blocks of code at once?
Kevin Scales
  • Aug 17, 2020 10:46 PM UTC
Hi Isaiah,
There are three ways to make comments, but they are not block comments. You can use REM or ! at the start of a line, and you can use # to append a comment on the same line as a piece of code (but not inside a string, in that case it's just part of the string).
Kevin Scales
