about macro getmtf
  • Feb 10, 2021 10:53 PM UTC
  • 419 views
Hi, I want to do a loop to get a lot of MTF curves. How do I do with GETMTF?
I know how to run it in a single time, but if I want to change object distance every time and rerun the GETMTF,
how should I do the loop? How to set object distance at ZPL macro?
Thanks a lot.
Best answer by Berta.Bernad
Hi Weihua,
You can set object distance (and another properties of surfaces) with the keywords SETSURFACEPROPERTY/SURP
The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > SETSURFACEPROPERTY, SURP
And then use a FOR loop to change it. The sintax for FOR loops is the following:
FOR variable, start_value, stop_value, increment
(commands)
NEXT
So something like this will change the object distance from 10 to 100 with an increment of 10 and retrieve the MTF:
Berta.Bernad
  • Feb 11, 2021 9:54 AM UTC
Hi Weihua,
(commands)
NEXT
