ZOS-API Python how to access HuygensPsfCrossSection settings
  • Aug 2, 2023 3:47 PM UTC
  • 154 views
lin
I’m trying to convert the following C# code snippet:
var hpsf =TheSystem.Analyses.New_Analysis(AnalysisIDM.HuygensPsfCrossSection);
var hpsf_settings = hpsf.GetSettings() as IAS_HuygensPsfCrossSection;
hpsf_settings.PupilSampleSize = (SampleSizes)(_pupilSampling + 1);
hpsf_settings.ImageSampleSize = (SampleSizes)(_imageSampling + 1);
hpsf_settings.ImageDelta = 0;
into Python:
hpsf= TheSystem.Analyses.New_Analysis(ZOSAPI.Analysis.AnalysisIDM.HuygensPsfCrossSection)
hpsf_setting=hpsf.GetSettings()
but I got error message
AttributeError: 'IAS_' object has no attribute 'ImageDelt
How can I cast  hpsf_setting returned by GetSettings() into a HuygensPsfCrossSection specific object?
Thank you very much!
lin
Benjamin.N
  • Visible
  • Aug 3, 2023 4:07 AM UTC
Hi lin,
this sounds like a known issue with PythonNET 3.x for which @MichaelH provided a nice workaround recently:
PythonNET 3.x is "Fixed" | Zemax Community
In short: replace
with
hpsf_setting = hpsf.GetSettings().__implementation__
and your code should work.
Best regards
Benjamin
lin
  • Aug 3, 2023 3:26 PM UTC
Thank you very much, Benjamin, for your helpful answer!
