Error using ZOS-API in Matlab
  • Jan 22, 2025 7:57 AM UTC
  • 11 replies
  • 1275 views
My codes (that were working with the 2024 version) do not work anymore with the 2025 release.
this is the error I get in the function “InitConnection()”:
Message: Could not load file or assembly 'ZemaxEngine.dll' or one of its dependencies. The dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A)
Source: mscorlib
HelpLink: None
Best answer by Julia
Hi bostanem,
I just updated my Matlab to Update5, I experience no error with this version.
Prasath R
  • Jan 24, 2025 4:49 PM UTC
Hi Luca,
You might want to try changing the directory mentioned in this post. Hopefully, it will help.
Matlab examples failing to connect to OpticStudio | Zemax Community
  • Jan 29, 2025 11:19 AM UTC
That part of the code works well, the error appears when I try to execute the line
app = TheConnection.CreateNewApplication()
NicoloAzzaroli
I have exactly the same issue.
Waiting for a solution from Zemax
Julia
  • Feb 7, 2025 10:26 AM UTC
Hi all,
Updating MATLAB to the latest version should resolve this issue. Please try updating and let us know how it goes.
下载 MATLAB、Simulink、Stateflow 和其他 MathWorks 产品
Julia
bostanem
  • Mar 18, 2025 8:52 AM UTC
Hi all,
I am facing the same problem and updating to the latest Matlab (ie version R2024b) did not solve the problem. The method CreateNewApplication()results in the same error:
Message: Could not load file or assembly 'ZemaxEngine.dll' or one of its dependencies. A dynamic link library
Source: mscorlib
HelpLink: None
FYI, I am using OpticStudio 2025.
Julia
  • Mar 18, 2025 9:01 AM UTC
Hi bostanem,
Would you please try the version below?
Julia
bostanem
  • Mar 18, 2025 9:18 AM UTC
Hi Julia,
Thanks a lot. It seems that I can install Update 5 (and not 4). Would that be okay?
Julia
  • Mar 18, 2025 9:41 AM UTC
Hi bostanem,
bostanem
  • Mar 18, 2025 2:37 PM UTC
Thanks Julia, this seems to fix the issue for me. I appreciate your help.
  • Apr 29, 2025 1:40 PM UTC
Date: April 29, 2025.
The latest available from Matlab is now R2024b, update 6 (not 5).   When I install update 6 of Matlab, I have the same problem, using the sample scripts from Zemax:
success = ZOSAPI_NetHelper.ZOSAPI_Initializer.Initialize();
returns 0 instead of a 1.
Prasath R
  • May 18, 2025 2:44 PM UTC
Hi Bowen,
Thank you for your update in the forum post. I'm sharing it here for the reference of other users.
ZOS-API Initialization Error in Matlab | Zemax Community
