ZOS-API non-sequential object not behaving the way I want it to
  • August 10, 2021
  • 249 views
Hi guys
I have a very simple POB object which is just a wedge, and I’m trying to see how the angle between the internal and external reflective surfaces change with tilt angle rotation around x. I can do this fine in OpticsStudio, by altering the TiltAroundX in the non-sequential component editor.
Screenshot of simple design
I then made a C# standalone app, so that I could control what I wanted programmatically.
I open up the file, no problems:
 IOpticalSystem TheSystem = TheApplication.PrimarySystem;
            // Add your custom code here...
            ///open relevant file
            bool SuccessfulFileOpen = TheSystem.LoadFile(FQP,
                saveIfNeeded: false
            Console.WriteLine("File succesfully opened: " + SuccessfulFileOpen);
            Console.WriteLine(FQP);
I then access the object to make sure it’s thr right one:
INonSeqEditor NCE = TheSystem.NCE;
            INCERow Object_n = NCE.GetObjectAt(ObjectNumber: 1);
            Console.WriteLine("Object Comment: " + Object_n.Comment);
And set up a batch ray trace
 //set up ray tracing
            var rayTracer = TheSystem.Tools.OpenBatchRayTrace();
            var nRays = 5000;
            var normUnPolData = rayTracer.CreateNormUnpol(nRays, ZOSAPI.Tools.RayTrace.RaysType.Real, nSurfaces);
            var calcOPD = ZOSAPI.Tools.RayTrace.OPDMode.None;
Last step is I increment over all the tilt angles as follows:
   var start = -2;
            var end = -22;
            for (double j = start; j >= end; j--)
                Object_n.TiltAboutX = j;
                //TheSystem.Save();
                //clear data from batch
                normUnPolData.ClearData();
                List<Tuple<double, double, double>> xyz = new List<Tuple<double, double, double>>();
                for (int ray = 0; ray <= nRays; ray++)
                    var hx = NormRandom(1);
                    var hy = NormRandom(1); ;
                    var rand_px = NormRandom(1);
                    var rand_py = NormRandom(1);
                    while (rand_px * rand_px + rand_py * rand_py > 1)
                    normUnPolData.AddRay(1, rand_px, rand_py, 0, 0, calcOPD);
                rayTracer.RunAndWaitForCompletion();
                normUnPolData.StartReadingResults();
                    var rayN = 0;
                    double X;
                    double Z;
                    double Y;
                    var error = 0;
                    var vign = 0;
                    double A, B, C, D, E, F, G, H = 0;
                    bool success = normUnPolData.ReadNextResult(out rayN, out error, out vign, out X, out Y, out Z, out A, out B, out C, out D, out E, out F, out G, out H);
                    xyz.Add(new Tuple<double, double, double>(X, Y, Z));
And collect the data. In my eyes, this is identical to what I would be doing inside OpticsStudio, but for some reason, it doesn’t seem to work like it does in the GUI. Am I doing anything wrong? I’m varying the TiltAboutX in increments, collecting rays, and last step not shown is saving them to a CSV file.
However, when I plot the data in python, I get the following:
Which is not right, so I must be doing something wrong in the code.
I’ve even tried to change the TiltAroundX to say -2, saved when it gets to -22 in the C# program, and then opened it up in the GUI, and the wedge is at that saved angle, so I know I’m rotating the right object in the right way.
Any help would be greatly helpful!
Hi Alexander,
Can you share your code and an example file demonstrating the issue? While what you describe make sense to me, there might be issues elsewhere in your code. I doubt it has to do with the POB.
Looking forward to hearing back from you.
  • 1141 replies
  • September 6, 2021
Hi Alexander,
