ZOS_API funtion to check wether a file is in sequential or non-sequential mode
  • Apr 23, 2020 2:31 PM UTC
  • 90 views
I am writing a matlab script to export a .zmx as CAD. I'd like it to work with sequential and non-sequential files. Therfore the script should check what mode the file is in. I could only find:
bool ZOSAPI.Tools.General.IExportCAD.SequentialSettingsEnabled
which:
Gets a value indicating whether or not the sequential-only settings are used.
true if the sequentials settings are available; otherwise, false.
Is there no higher level function to get the file's mode?
I feel like that is a somewhat convoluted way to get the mode.
Best answer by Ali H
You can use the mode property of the IOpticalSystem Interface to return the status of the system as an enumeration:
Then comapre it to the enumeration to yield true or false:
TheSystem.Mode == ZOSAPI.SystemType.Sequential
TheSystem.Mode == ZOSAPI.SystemType.NonSequential
I hope that helps!
Ali H
  • Visible
  • Apr 24, 2020 7:12 AM UTC
I hope that helps!
That is perfect. Thank you very much!
