The problem with microsoft excel Connect to ZEMAX
  • Aug 28, 2020 1:27 AM UTC
  • 413 views
The Attach Files is my problem.
Why i can't Connect to ZEMAX with microsoft excel .
Can you teach me how to Connect to ZEMAX.
Thank you!
Hi Shen-Bo,
I don't t think you can connect to OpticStudio with Excel. You will need to create a standalone mode instead.
I have attached an example that you can try. Let me know if it works.
Sandrine
HI Sandrine,
This example is create a new one zemax file.
I want to get data from zemax with excel to analysis.
Is have the method to connect to my old  zemax file ?
Thank you
Allie
  • Aug 31, 2020 5:28 PM UTC
Hi Sheng-BO,
When you're using the ZOS-API with Excel, all of the API-specific commands will be open to you! This includes the commands LoadFile and LoadNewSystem. Each of these commands will allow you to load an already-generated lens file into Excel. I am attaching a quick example of how we can open a file and extract some data.
In this example, you will see that the sample file Cooke 40 degree field.zmx is opened. This sample file is available in your {Zemax}\Samples directory. From there, the example will extract the Radius of surface 3 and print it to the first cell in the Excel workbook:
For printing to Excel, those commands are specific to that program. In my case, I hard-coded the output to a specific cell, but there are certainly other methods to write data to Excel as discussed here: https://analysistabs.com/excel-vba/write-data-to-worksheet-cell/.
For API-specific commands - these are almost always the same across programming languages. Take a look at the Knowledgebase article 'Sample code for ZOS-API users' for some examples, and the article 'Navigating the ZOS-API Syntax Help Document' for a guide on how to find the commands you need!
Let us know if you have any other questions about this. And have a great week!
Allie
Thank you
