Save eulumdat/ies file via ZOS-API
  • February 11, 2025
  • 48 views
still can't we save polar detector data in eulumdat/ies files with ZOS-API? Is there an alternative solution? And most importantly, can we hope that it will be implemented?
Thank you!
Best answer by Iari.Marino
but one of the hopes I had was to avoid generating the ies/ldt file myself, assuming that it would be of interest to OpticStudio users to have an API function that would do it for them ;)
Iari
  • 1141 replies
  • February 13, 2025
@Iari.Marino
The EULUMDAT File Format seem to be described here: https://docs.agi32.com/PhotometricToolbox/Content/Open_Tool/eulumdat_file_format.htm
OpticStudio also ships with a sample LDT file in your documents folder: …/Zemax/Objects/Sources/EULUMDAT/Sample.LDT. This is a text file, that can be read with any text editor.
Seems like if you extract the detector data with the ZOSAPI, you could then do the conversion yourself.
Let us know if you go down that path and get something out of it.
Otherwise, you can always keep your hopes up 😊
  • 10 replies
  • February 13, 2025
Iari
  • 1141 replies
  • February 13, 2025
No worries. If you implement this, you can consider contributing it to ZOSPy in that way it will be easier to distribute to other users.
