Python connection
  • Jul 19, 2022 9:07 AM UTC
  • 652 views
Good morning,
I’m trying to connect Zemax with Python and I know that ZOS API and PyZDDE are possible options to use. Now I wonder if it is possible to use PyZDDE with the latest version of Zemax OpticStudio or if some functionalities are not supported with this connection.
Hi Marta,
I really don’t know PyZDDE, so I cannot say. However, the ZOS-API fully supports the wavefront map. In fact, a year ago, I wrote a Python code snipet to display the wavefront map and print the RMS wavefront error for another user. The code is available as a Gist, and here’s the relevant part (you’d have to add this code to a template generated in OpticStudio by pressing: Programming..Python..Standalone Application/Interactive Extension, this template contains the reshape function defined below):
# Create a Wavefront Map analysis
MyWavefrontMap = TheSystem.Analyses.New_Analysis(ZOSAPI.Analysis.AnalysisIDM.WavefrontMap)
# Retrieve Wavefront Map settings
MyWavefrontMapSettings = MyWavefrontMap.GetSettings()
# Change to field number 2
MyWavefrontMapSettings.Field.SetFieldNumber(2)
# Apply new settings
MyWavefrontMap.ApplyAndWaitForCompletion()
# Retrieve Wavefront Map results
MyWavefrontMapResults = MyWavefrontMap.GetResults()
MyWavefrontMapGrid = MyWavefrontMapResults.GetDataGrid(0).Values
MyWavefrontMapArray = reshape(MyWavefrontMapGrid, MyWavefrontMapGrid.GetLength(0), MyWavefrontMapGrid.GetLength(1))
# Plot results
plt.figure()
plt.imshow(MyWavefrontMapArray)
plt.show()
# (additional) Retrieve RMS wavefront error from a Merit Function operand
RMS_WaveFront = TheSystem.MFE.GetOperandValue(ZOSAPI.Editors.MFE.MeritOperandType.ZERN, -4, 2, 2, 1, 0, 0, 0, 0)
print(RMS_WaveFront)
I hope this helps. Take care,
Hi mbelio,
As far as I know, PyZDDE isn’t developped (and therefore not supported) by Zemax. Assuming this is the most up-to-date repo for PyZDDE, the most recent commit was 5 years ago.
I’d advise to use the ZOS-API, which has been developped by Zemax, and recieves regular updates (notably with the .net connexion recently).
I cannot comment for the functionalities of PyZDDE, but most of the OpticStudio features have already been implemented in the ZOS-API. Perhaps this article can give some insights about the DDE extension itself.
What features in particular are you interested in?
  • Jul 19, 2022 10:23 AM UTC
Thank you very much for your answer,
I want to do a kind of WFE sensitivity analysis. I.e. perturb the elements of my system and get the change in the performance, in terms of Zernike residuals, RMS residual error, wavefront map etc
I know that it is possible to use both python libraries but I’m not sure if PyZDDE will support this.
Best wishes,
Marta
  • Jul 19, 2022 11:36 AM UTC
Hi Marta,
# Plot results
plt.figure()
plt.show()
