Mathematica set DoubleValue parameter
  • Feb 14, 2022 8:34 AM UTC
  • 308 views
I am able to control IntegerValue parameters of objects in ZEMAX from Mathematica
theSystem@NCE@GetObjectAt[8]@GetObjectCell[ObjectColumn`Par2]@IntegerValue = 512;
however DoubleValue object returns an error
theSystem@NCE@GetObjectAt[1]@GetObjectCell[ObjectColumn`Par6]@DoubleValue = 10.1;
NET::netexcptn: A .NET exception occurred: System.ArgumentException: Expected Double, got 'String'
   at ZemaxUI.ZOSAPI.Editors.ZOSAPI_EditorCellBase.set_DoubleValue(Double value).
What is the syntax  to control a DoubleValue object?
Thank and BR,
Jozef
Best answer by MichaelH
Hi Jozef,
When I’m dealing with changing cells in an editor that could take multiple values (i.e. the parameters in the LDE/NCE or the Hx/Hy/Px/Py/Ex/Ey columns in the MFE), I always like to wrap my cell assignment in a short switch statement.  All cells in the API can have 1 of 3 values:
  • ZOSAPI.Editors.CellDataType.Integer
  • ZOSAPI.Editors.CellDataType.Double
  • ZOSAPI.Editors.CellDataType.String
If the current is expecting a different data type than what you are assigning, you will get the error you saw.  A short pseudo-code (sorry, I don’t know Mathematica) would then look like:
switch(cell.DataType){
   case ZOSAPI.Editors.CellDataType.Integer:
      cell.IntegerValue = val; break;
   case ZOSAPI.Editors.CellDataType.Double:
      cell.DoubleValue = val; break;
   case ZOSAPI.Editors.CellDataType.String:
      cell.Value = val; break;
  • Feb 14, 2022 8:39 AM UTC
solved my question .. i was looking into wrong parameter (pobjects Par6 was not a DoubleValue).
  • Feb 14, 2022 8:53 PM UTC
Hi Jozef,
