Issues with ZOS-API
Andy.Kruse
I’m using a grin 5 surface using a material from an edited SGRIN.dat file and getting errors upon loading it in a Python standalone.
If I open the file in a regular OpticStudio window, there is no error message and it works perfectly. However, if I try to load it in Python, the grin 5 surface is causing some issues. In Python, I will get the status "Can't find glass *CAF2* in catalog!" (CAF2 is the first glass after the GRIN 5 surface). If I save the file in Python and open it in OpticStudio, then it will throw the error “Can’t find GRIN 5 glass *customglassname* in SGRIN.DAT!”. This can be resolved if I change the GRIN 5 material to air, which then triggers a glass not found error for every glass in the rest of the system. This is because in the material catalogues, all of the catalogues I had been using have somehow been removed from “Catalogues to use”. After fixing that up, if I change the GRIN 5 material back to what it was originally, there is no error and it works as it did before.
From there I can save the file and reopen it with no issues in an OpticStudio window, but will always have the issue if opened and saved in Python.
I tried saving CFG files in OpticStudio and loading them in Python using TheConnection.PreferencesFile = ‘path/to/cfg’, but it does not seem to work. I tried changing the glass catalogue folder to another that has the edited SGRIN.dat
Any help on this would be very much appreciated, as this functionality is critical to our projects.
Be the first to reply!
