Image Simulation in Matlab - Black Output Image
  • June 29, 2023
  • 361 views
BeauDiddley
Hi all,
I am looking to build an API in MATLAB to perform image simulations in Zemax. I am having trouble with the basic case.
My MATLAB Standalone Application:
function [] = BeginApplication(TheApplication, filename)
import ZOSAPI.*;
TheSystem.LoadFile(filename, false);
% Create analysis
im_analysis = TheSystem.Analyses.New_ImageSimulation();
im_settings = im_analysis.GetSettings();
im_settings.OutputFile = 'testfinal.BMP';
im_analysis.ApplyAndWaitForCompletion();
end
If I run this on the “Double Gauss 5 degree field.zmx” sample file, I get an image generated that simply [0,0,0]  pixels.
I can run the simulation on the same .zmx file in OpticsStudio without issue.
Any ideas what I am doing wrong?
Best answer by BeauDiddley
That worked great, Csilla! Thank you.
Hi @BeauDiddley ,
Thanks for your question here on the Community Forums!
I have tested your MATLAB code on my side, and when the Zemax sample file was loaded correctly from the API, then I got a reasonable output as below:
I only got an empty output like you when the sample file was not loaded correctly from the API:
Please note that you need to define the full path together with the extension of the file, and not just the file name, in order for the LoadFile function to work correctly.
You may use the following code to load the Double Gauss file:
samplesFolder = TheApplication.SamplesDir;
DGfile = System.String.Concat(samplesFolder, '\Sequential\Objectives\Double Gauss 5 degree field.zos');
TheSystem.LoadFile(DGfile, false)
Also, the LoadFile function returns a bool variable which indicates whether the loading process was successful or not. Please double-check that to make sure the file loading was completed successfully.
Csilla
Benjamin.N
  • Visible
  • June 29, 2023
I recreated your example in Python and it outputs a more meaningful file:
    System = ZOSAPI.ZOSAPI_Connection().CreateNewApplication().PrimarySystem
System.LoadFile(file, False)
im_analysis = System.Analyses.New_ImageSimulation()
interface = ZOSAPI.Analysis.Settings.ExtendedScene.IAS_ImageSimulation
im_settings = interface(im_analysis.GetSettings())
Note that the “interface = ...“ part is an adaption to Python which should not be necessary for Matlab (to my knowledge).
Csilla Timar-Fulep
Hi @BeauDiddley ,
Csilla
BeauDiddley
  • July 13, 2023
Hi @BeauDiddley ,
Csilla
