I have a question about NSC by Python program optimization.
The program must iteratively run the local optimization defined by Zemax.
However, after running some local optimizations, the optimization becomes very slow.
How to speed up the optimization of Zemax NSC through Python programs?
Do you have an example of your code to share so we can reproduce the issue? Its hard to say how a program can be optimized without seeing it (at least for me). From your description of the problem, are you opening and closing the optimization tool at every iteration of the loop? It could be then that some resources (cores) become locked somehow and are not available for the following iterations. I’m just wondering at this point, but if that’s what you are doing, could you instead open the optimization tool once before the start of the loop and only close it after the loop is done. Obviously, if you need to open another tool during an iteration, this will not work (only one tool can be open at a time).
Hi, David,
Thanks for your reply.
When we optimize the coefficient of the freeform,
we always start from the low order (e.g., radius) to high order term (e.g., R^4, R^6,R^8, ...).
step 1 From the begining, the low order terms are set to be variables and do the optimization.
step 2 Then the high order terms would be set to be variables and do the optimization Sequentially.
step 3 Then optimize other lens, go back to step 1.
Therefore, the optimization must be open and close every time.
The following is my optimiztion function.
def optimization(TheTOOL):
LocalOpt = TheTOOL.OpenLocalOptimization()
#Automatic=0, Fixed_1_Cycle=1, Fixed_5_Cycles=2,
#Fixed_10_Cycles=3, Fixed_50_Cycles=4, Infinite=5
LocalOpt.Cycles = ZOSAPI.Tools.Optimization.OptimizationCycles.Fixed_5_Cycles
LocalOpt.RunAndWaitForCompletion()
LocalOpt.Close()
I know that the running speed depends on the number of the variables.
But when the program run other lens, the running speed is slow down very much even shut down.
Could any method speed up the running speed?
Best wishes,
CM tsai
You could also do the tool opening and closing outside this optimization
function. In pseudo code you could do:
def optimization(theOptimizer):
theOptimizer.RunAndWaitForCompletion()
def main():
theOptimizer = TheSystem...
for:
optimization(optimization tool)
theOptimizer.Close()
I got confused a bit, are you saying that the optimization is slow in general or it gets slower as the code runs?
In addition to
Hi, jwbeenakker and David.Nguyen,
The following is the pseduo code.
def setMFETarget(imgName,TFlux,TheMFE,opBng,ncol,nrow):
#給定影像,設定MFE偵測器上target值
TheMFE.GetOperandAt(opBng-1).Target=TFlux
img = cv2.imread(imgName) # 讀取圖片
imgGray = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY);
pxFlux=float(TFlux)*imgGray/imgGray.sum()
for i in range(nrow):
nn=i*ncol
for j in range(ncol):
TheMFE.GetOperandAt(nn+j+opBng).Target=pxFlux>i] j]
return pxFlux
def getRandomPar():
scl=0.475
Rx=random.uniform(90, 130)
Ry=random.uniform(35, 70)
#Kx=random.uniform(-1, 1)*10**(random.uniform(0, 4))
#Ky=random.uniform(-1, 1)*10**(random.uniform(0, 4))
rndPar=>0,Rx*scl,Ry*scl,Rx,Ry,0,0]
return rndPar
LocalOpt.Close()
def setParTo0(m1):
xidBng=14
yidBng=30
zidBng=46
nOder=16
for i in range(nOder):
m1.GetObjectCell(parN/i+xidBng]).DoubleValue = 0
m1.GetObjectCell(parNei+yidBng]).DoubleValue = 0
m1.GetObjectCell(parNui+zidBng]).DoubleValue = 0
def optmSingle(TheSystem,parN,opBng,ncol,nrow,cnt):
TheNCE = TheSystem.NCE
#TheMFE = TheSystem.MFE
TheTOOL = TheSystem.Tools
xidBng=14
yidBng=30
zidBng=46
nOder=16
rndPar=getRandomPar()
m1=TheNCE.GetObjectAt(1)
for i in range(1,7):
m1.GetObjectCell(parN1i]).DoubleValue = rndPari]
setParTo0(m1)
print('optimization =',i,datetime.now())
Solver=m1.GetObjectCell(parNbi+xidBng]).CreateSolveType(ZOSAPI.Editors.SolveType.Variable)
m1.GetObjectCell(parNii+xidBng]).SetSolveData(Solver)
Solver=m1.GetObjectCell(parN[i+yidBng]).CreateSolveType(ZOSAPI.Editors.SolveType.Variable)
m1.GetObjectCell(parNpi+yidBng]).SetSolveData(Solver)
Solver=m1.GetObjectCell(parNei+zidBng]).CreateSolveType(ZOSAPI.Editors.SolveType.Variable)
m1.GetObjectCell(parNei+zidBng]).SetSolveData(Solver)
print('Variable Fixed =',i,datetime.now())
Solver=m1.GetObjectCell(parNzi+xidBng]).CreateSolveType(ZOSAPI.Editors.SolveType.Fixed)
m1.GetObjectCell(parNli+xidBng]).SetSolveData(Solver)
Solver=m1.GetObjectCell(parN i+yidBng]).CreateSolveType(ZOSAPI.Editors.SolveType.Fixed)
m1.GetObjectCell(parN Solver=m1.GetObjectCell(parN i+zidBng]).CreateSolveType(ZOSAPI.Editors.SolveType.Fixed)
print('Over 1 OPMT =',i,datetime.now())
if __name__ == '__main__':
for i in range(3):
ss=str(i).zfill(4)
imgName=f'p{ss}.bmp'
print(imgName,datetime.now())
pxFlux=setMFETarget(imgName,power,TheMFE,opBng,ncol,nrow)
optmSingle(TheSystem,parN,opBng,ncol,nrow,i)
The running results show as
p0000.bmp 2024-04-09 21:06:05.082130
optimization = 0 2024-04-09 21:06:12.615857
optimization = 1 2024-04-09 21:06:19.887321
optimization = 2 2024-04-09 21:06:29.702357
optimization = 3 2024-04-09 21:06:42.049635
optimization = 4 2024-04-09 21:06:52.835375
optimization = 5 2024-04-09 21:07:04.246019
optimization = 6 2024-04-09 21:07:17.676560
optimization = 7 2024-04-09 21:07:32.591460
optimization = 8 2024-04-09 21:07:52.054525
optimization = 9 2024-04-09 21:08:11.587495
optimization = 10 2024-04-09 21:08:42.282695
optimization = 11 2024-04-09 21:09:17.221488
optimization = 12 2024-04-09 21:09:39.321940
optimization = 13 2024-04-09 21:10:01.000962
optimization = 14 2024-04-09 21:10:32.857089
optimization = 15 2024-04-09 21:10:59.061922
Variable Fixed = 15 2024-04-09 21:11:37.625550
Over 1 OPMT = 15 2024-04-09 21:11:37.752509
p0001.bmp 2024-04-09 21:11:38.052760
optimization = 0 2024-04-09 21:11:45.741525
optimization = 1 2024-04-09 21:11:52.989084
optimization = 2 2024-04-09 21:12:03.875797
optimization = 3 2024-04-09 21:12:15.174620
optimization = 4 2024-04-09 21:12:27.627474
optimization = 5 2024-04-09 21:12:45.601644
optimization = 6 2024-04-09 21:13:08.888544
optimization = 7 2024-04-09 21:13:33.687291
optimization = 8 2024-04-09 21:14:06.230512
optimization = 9 2024-04-09 21:14:36.535561
optimization = 10 2024-04-09 21:15:16.283523
optimization = 11 2024-04-09 21:16:05.355903
optimization = 12 2024-04-09 21:16:45.097957
optimization = 13 2024-04-09 21:17:39.770961
optimization = 14 2024-04-09 21:19:03.867097
optimization = 15 2024-04-09 21:20:30.030670
Variable Fixed = 15 2024-04-09 21:22:02.387894
Over 1 OPMT = 15 2024-04-09 21:22:02.522653
p0002.bmp 2024-04-09 21:22:02.831023
optimization = 0 2024-04-09 21:22:18.315095
optimization = 1 2024-04-09 21:22:40.599438
optimization = 2 2024-04-09 21:25:36.438176
optimization = 3 2024-04-09 21:31:50.944993
optimization = 4 2024-04-09 23:23:54.578955
optimization = 5 2024-04-10 00:23:31.163572
optimization = 6 2024-04-10 01:57:20.572472
optimization = 7 2024-04-10 03:29:10.087029
optimization = 8 2024-04-10 05:08:59.642493
optimization = 9 2024-04-10 06:55:14.068808
For p0002.bmp, the optimization is too slow.
Does any method be able to speed up the optimization?
What happens when you start the optimisation with p0002.bmp?
Hi, jwbeenakker
Just same as the p0000.bmp.
step 1 According to the gray level of photo p0002.bmp (10x26 pixels),
set the MFE targe from the operator 7 to operator 266.
step 2 Get random value to the radiuses of biconic Zernike surface.
step 3 Then run optmSingle(TheSystem,parN,opBng,ncol,nrow,i)
But the p0002.bmp is same as p0000.bmp and p0001.bmp.
Sorry to insist but could you try opening and closing the optimizer only once? I just want to see if it makes a difference.
def optimization(LocalOpt):
def optmSingle(..., LocalOpt):
LocalOpt = TheSystem.Tools.OpenLocalOptimization()
for i in range(3):
LocalOpt.Close()
Hi, David.Nguyen,
Thanks for your suggestion.
The suggestion program seems to work normally.
But I doubt that the problem comes from the object (Biconic Zernike Surface) for Sag problem.
When this object sets the X-Half-Width or Y Half-Width to be larger than Radius X or Radius Y,
it could show error as
Does the ZOS-API support any exceptions when error happens such as sag problem?
Does the ZOS-API support the optimization escape when the running too much time?
Apologies, I am not saying the problem is related to a specific object. I was wondering if the problem is that when you start the optimization the first time, some cores get reserved for the optimization and even though you close the optimizer, perhaps they could still be locked somehow? This means you have less cores for the second optimization, and eventually you run out of cores? Again, I’m not saying this is the problem, but I’m just curious to know whether it makes a difference.
Hi, David.Nguyen,
Does the ZOS-API support any exceptions or optimization interrupt when error happens such as sag problem or optimization too much time?
I don’t think an exception is raised for an error message like you are showing and I also don’t think it has a timeout that would prevent long optimization times. I could be wrong though. You may want to have a read at this post:
