how to Ignore Surface in API
  • February 3, 2022
  • 434 views
John.Hygelund
I’m still new to the API and having trouble getting and setting the “Ignore this surface” via the API.
I’m working in Matlab and trying:
TheLDE.GetSurfaceAt(4).GetSurfaceTypeSettings(ZOSAPI.Editors.LDE.ILDETypeData.IgnoreSurface)
but get the error:
The property 'IgnoreSurface' in class 'ZOSAPI.Editors.LDE.ILDETypeData' must be accessed from a class instance because it is not a Constant property.
Can someone point me in the right direction?
Thank you,
John
Best answer by Jeff.Wilde
Try this to flip the IgnoreSurface switch from Off (0) to On (1) :
surf4 = TheSystem.LDE.GetSurfaceAt(4);
surf4.TypeData.IgnoreSurface = 1;
Then you can see the results:
  • 514 replies
  • February 4, 2022
John.Hygelund
  • 71 replies
  • February 7, 2022
Excellent, this works. Thank you Jeff.
clo
  • 6 replies
  • January 9, 2023
Hi, I would like to do the same but in non sequential mode.
I tried this lines but it’s not working :
        surf4 = TheSystem.NCE.GetObjectAt(4)
        surf4.TypeData.IgnoreObjects = 1
Do you know why and what I can do ?
Thank you very much.
  • 514 replies
  • January 9, 2023
See response here:
