how to Ignore Surface in API
  • Feb 3, 2022 6:36 PM UTC
  • 605 views
John.Hygelund
I’m still new to the API and having trouble getting and setting the “Ignore this surface” via the API.
I’m working in Matlab and trying:
TheLDE.GetSurfaceAt(4).GetSurfaceTypeSettings(ZOSAPI.Editors.LDE.ILDETypeData.IgnoreSurface)
but get the error:
The property 'IgnoreSurface' in class 'ZOSAPI.Editors.LDE.ILDETypeData' must be accessed from a class instance because it is not a Constant property.
Can someone point me in the right direction?
Thank you,
John
Best answer by Jeff.Wilde
Try this to flip the IgnoreSurface switch from Off (0) to On (1) :
surf4 = TheSystem.LDE.GetSurfaceAt(4);
surf4.TypeData.IgnoreSurface = 1;
Then you can see the results:
  • Feb 4, 2022 6:33 AM UTC
John.Hygelund
  • Feb 7, 2022 9:07 PM UTC
Excellent, this works. Thank you Jeff.
clo
  • Jan 9, 2023 1:54 PM UTC
Hi, I would like to do the same but in non sequential mode.
I tried this lines but it’s not working :
        surf4 = TheSystem.NCE.GetObjectAt(4)
        surf4.TypeData.IgnoreObjects = 1
Do you know why and what I can do ?
Thank you very much.
  • Jan 9, 2023 6:29 PM UTC
See response here:
