How to ignore Object in API ?
  • January 9, 2023
  • 423 views
clo
Hello to all,
I read the topic about : “how to ignore Surface in API”. I tried to do something similar for non-sequential object but it is not working.
        surf4 = TheSystem.NCE.GetObjectAt(4)
        surf4.TypeData.IgnoreObjects = 1
First TypeData.IgnoreObjects want a string but I don’t know what to write.
Thank you very much in advance fir your answer.
Clotilde
Best answer by Jeff.Wilde
Hi Clotilde,
Try using:  surf4.TypeData.RaysIgnoreObject = ZOSAPI.Editors.NCE.RaysIgnoreObjectType.Always;
  • January 9, 2023
Hi Clotilde,
clo
  • January 10, 2023
Hi Jeff,
Thank you very much for your answer !!
It is working :)
Clotilde
mocquin
  • March 3, 2025
Can someone confirm that the right-click “Consider and Show object” and “Ignore and Hide Object” are just shortcuts to the object’s Type data “Rays Ignore Object” and Draw data “Do not draw object” ?
@mocquin
I am quite sure that it is (at least that’s my working hypothesis). Do you have a reason to believe otherwise?
