How to change a value on Ray Rotator via MATLAB
  • Jun 18, 2021 1:22 PM UTC
  • 116 views
Something strange has happened. I had previously a code that worked and now it doesn't (I have updated ZEMAX since then).
The code I am having issues with, is changing an angle to 'Ray Rotator' in Par 3 or Par 4 (column 3 or 4 from Material on the editor list), which in this case is the angle of the rotationZ and rotationY. The problem is that I am getting error message:
Unable to use a value of type ZOSAPI.Editors.NCE.ObjectColumn as an index.
Error in GetAngle_Cond3_v2>writeTiltAboutY (line 142)
        NCEObj.GetObjectCell(ZOSAPI.Editors.NCE.ObjectColumn.Par4).DoubleValue = y;
Error in GetAngle_Cond3_v2>BeginApplication (line 70)
        writeTiltAboutY(o23, angleY);
Error in GetAngle_Cond3_v2 (line 14)
        r = BeginApplication(TheApplication, args);
 My code is:
  o23 = TheNCE.GetObjectAt(14);
        % Set the Tilt Angle of Y
    function writeTiltAboutY(NCEObj, y)
        NCEObj.GetObjectCell(ZOSAPI.Editors.NCE.ObjectColumn.Par3).DoubleValue = y;
    end
I have no idea what that means.
Any ideas how to change the angle from matlab in the editor,
NCEObj.GetObjectCell(ZOSAPI.Editors.NCE.ObjectColumn.Par3).DoubleValue = y?
doesn't seem to be working. I also tried
NCEObj.RotateY = y,
but its not doing what I want. Nothing seem to be happening.
I also tried
o23.GetObjectCell(ZOSAPI.Editors.NCE.ObjectColumn.Par3).IntegerValue = angleY
The row values are correct according to the editor list.
Its a non-sequential analysis.
Looking further I can see that, 023 is empty [], even though i write:
TheNCE is however containing something.
TheNCE =
  ZOSAPI_NCE with properties:
    AllObjectsTypeSource: [1×1 System.Collections.Generic.List>]
             EveryObject: [1×1 System.Collections.Generic.List]
              AllSources: [1×1 System.Collections.Generic.List]
            AllDetectors: [1×1 System.Collections.Generic.List]
              AllObjects: [1×1 System.Collections.Generic.List]
       RowToObjectOffset: 1
           ActiveSurface: 1
         NumberOfObjects: 1
             FirstColumn: Comment
              LastColumn: Par250
                    Type: NonSequentialComponents
               MinColumn: 1
               MaxColumn: 260
            NumberOfRows: 1
                  Editor: NCE
                  Parent: [1×1 ZemaxUI.ZOSAPI.ZemaxSystem]
Any ideas?
Thanks for any assistance!
Hi Susan,
This probably won't help you, but in a Python Interactive Extension with the latest update of OS, the following code works for me:
MyRayRotator = TheSystem.NCE.GetObjectAt(2)
MyRayRotator.GetObjectCell(ZOSAPI.Editors.NCE.ObjectColumn.Par3).DoubleValue = 5.3
I have a Ray Rotator in line 2 of my NCE, and its value gets updated to 5.3.
I don't own a MATLAB licence to test, but can you share more of your code for troubleshooting?
  • Jun 22, 2021 5:11 PM UTC
Hi Susan,
