How can I set imageDelta of fftpsf in ZOSAPI_matlab
  • Jan 13, 2021 6:39 AM UTC
  • 255 views
I want to setting imageDelta of fftpsf on ZOS-API-MATLAB
my matlab code is below
I wonder How can I command imageDelta.
When I try ' newWin_Settings.ImageDelta = 0.5; '
There's some error with ' Attempted to index object 'null' '
In ZOS-API help document, We can handle imageDelta with 'double'
How do I input into MATLAB so I can change imagedelta of fftpsf?
my MATLAB code...
    TheAnalyses = TheSystem.Analyses;
    newWin = TheAnalyses.New_FftPsf();
    newWin_Settings = newWin.GetSettings();
    newWin_Settings.SampleSize = ZOSAPI.Analysis.Settings.Psf.PsfSampling.PsfS_512x512 ;
    newWin.ApplyAndWaitForCompletion();
    newWin_Results = newWin.GetResults();
   dataSeries = newWin_Results.DataSeries(1);
    psf= dataSeries.YData.Data.double; %psf
I have connected Matlab with the Interactive extension on \Zemax\Samples\Sequential\Objectives\Cooke 40 degree field.zmx. I then tried this:
TheApplication=ans;
newWin = TheSystem.Analyses.New_FftPsf();
newWin_Settings.ImageDelta= 0.8;
It works well and then I can see on the interface that it works.
Then for the results, you can check what the is returned:
As you can see, the FFT PSF does not return a DataSeries but a DataGrid.
So the syntax would be:
newWin_values =newWin_Results.GetDataGrid(0).Values.double;
This would be a matrix of values. You may want to have a look at that article: https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01650
Do not hesitate if you have any further questions.
Sandrine
