I’m writing a script to do a lot of automation and has a lot of inputs for different configurations. I’m trying to combine multiple .ZBF, each with a different field position. This means I need to use ZBFRESAMPLE to shift the images to match their offsets compared to the on-axis field. This is quite handy since I can use physical units to shift the image rather than try and figure out how many pixels I need to shift by.
The only other option I can think of is to have the API run a macro, however, I think I would need to have the ability to have the API input variables into a macro which I don’t think is possible.
Does anyone know if it’s possible to call just one ZPL function in API or do I need to figure out how to mix API and ZPL?
