Boundary constraints user-extension
  • Oct 29, 2021 3:00 PM UTC
  • 885 views
Hi everyone,
When specifying custom boundary constraints, I was using the Default Merit Function as a template, moving the default boundary constraints above DMFS and making my edits there.
I created a simple user-extension to speed up this process. This user-extension creates default boundary constraints at the top of a sequential Merit Function. It uses the default values (Min: 0 | Max: 1e+03 | Edge Thickness: 0) and only creates the relevant operands. If it is an air space it only creates MNCA, MXCA, and MNEA. If it is a glass space it only creates MNCG, MXCG, and MNEG.
Small update: it only adds boundary constraints to thicknesses that are variable.
Maybe this can be useful for someone else.
yuan.chen
  • Nov 1, 2021 1:35 AM UTC
Hi David,
This is exactly what I wanted when setting up the merit function operands, Thank you so much!
Yuan
