How to perform surface tilt & decenter (& surface irregularities) tolerancing in non-sequential mode ?
  • December 15, 2023
  • 318 views
Christophe.Weisse
For some use-cases it is more convenient to use pure non-sequential mode, for multi-pass systems for instance. Performing a tolerance analysis for surface tilts & decenters is not available with standard non-sequential tolerance operands:
  • TNPS can be used of course for element tilt & decenter,
  • TNPA can be used to tolerance the object parameter values, but surface tilt/decenter is not a parameter for most non-sequential geometries (standard lens, even asphere, for instance)
An option is then to use the compound lens object, together with Biconic Zernike Surfaces:
The Biconic Zernike Surfaces can be used to model a wide range of lens shapes, from standard to biconic, aspheres and Zernike Standard Sag Surface, as their sag is a combination of those sag definitions:
The other benefit of using this particular type of surface is that it also has tilts & decenters parameters:
  • Zernike terms Z2/Z3 can be used for X/Y tilts, for each surface,
  • Biconic Zernike Surfaces have built-in X/Y decenter parameters
They correspond to the following TNPA operand parameters:
As you can choose the number of Zernike terms that you can have for each Biconic Zernike Surface, you can also use the same approach to tolerance for Zernike surface irregularities.
Be the first to reply!
