HUD related materials
  • July 29, 2022
  • 534 views
yuan.chen
We have an KBA which describes some related tools and sample file made by my experienced colleague Sandrine.
https://support.zemax.com/hc/en-us/articles/1500005577782-Which-tools-to-use-when-working-on-a-Head-up-Display-
One important tool is the NSC Sag Map, you can find more information here:
NSC Sag Map User Analysis – Knowledgebase (zemax.com)
Besides, Steven has highlighted some tips:
​  https://community.zemax.com/people-pointers-9/tech-tip-tuesday-working-with-freeform-hud-elements-1838
https://community.zemax.com/people-pointers-9/tech-tip-tuesday-setting-up-hud-systems-1815
https://community.zemax.com/people-pointers-9/tech-tip-tuesday-hud-with-fea-and-the-opticstudio-star-module-1785
https://community.zemax.com/people-pointers-9/top-tip-tuesday-hud-1761
About stray light analysis, you can refer to:
Stray light analysis for Head-up-Display - Part 1 – Knowledgebase (zemax.com)
https://support.zemax.com/hc/en-us/articles/4412788138387
https://support.zemax.com/hc/en-us/articles/4412793979539
This is what Lumerical can do with HUD:
Polarization-Sensitive Plasmonic Reflectors for HUD – SPEOS Interoperability – Lumerical Support
The coating can be modelled using table coating:
We have a webinar in Chinese:
https://mp.weixin.qq.com/s/s7BK_aeabHDtB2qHOU8E6Q
​Sometimes the system is designed reversely. In this case, the relative illumination and distortion are inverse. If you want to check the relative illumination at the “object surface”, you can refer to this article.
How to check relative illumination at 'object' surface (verify the relative illumination theory) | Zemax Community
yuan.chen
  • 278 replies
  • October 19, 2022
Thanks to @Sandrine Auriol , we have a new article about HUD, the simulation is fantastic:
Head-Up Display (HUD) – Ansys Optics
yuan.chen
  • 278 replies
  • October 24, 2022
Michael uploaded code to generate the system that contains the surface converted from CAD file:
ZPL Macro:Fit CAD surface as a sequential surface | Zemax Community
Python fit object face (ex. for CAD) | Zemax Community
yuan.chen
  • 278 replies
  • November 16, 2022
yuan.chen
  • 278 replies
  • November 23, 2022
