Python fit object face (ex. for CAD)
  • Oct 24, 2022 2:59 AM UTC
  • 856 views
Michael Cheng
Attached file shows alternative method to the following code.
ZPL Macro:Fit CAD surface as a sequential surface
It uses ZOS-API with Python. The benefit is we will generate the fitting system automatically.
A document is provided to show a simple example about how to use it.
yuan.chen
  • Oct 24, 2022 5:23 AM UTC
If you encounter such problem:
AttributeError: module 'clr' has no attribute 'AddReference'
You can try to uninstall the clr and follow the instruction below:
Getting started with Python – Knowledgebase (zemax.com)
Julia
  • Oct 9, 2023 8:54 AM UTC
If you are using PythonNET 3.0 and experiencing the error below, you can use the attached file. For more information about the changes in PythonNET 3.0, please refer to the following discussion.
System.ArgumentException: since Python.NET 3.0 int can not be converted to Enum implicitly. Use Enum(int_value) in method Boolean ReadNextSegmentFull(Int32 ByRef, Int32 ByRef, Int32 ByRef, Int32 ByRef, Int32 ByRef, ZOSAPI.Tools.RayTrace.RayStatus ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Int32 ByRef, Int32 ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef, Double ByRef) ---> Python.Runtime.PythonException: since Python.NET 3.0 int can not be converted to Enum implicitly. Use Enum(int_value)
   --- End of inner exception stack trace ---<---
