Rigid-body motions (RBMs) in STAR, Part 2: A simple singlet
  • October 15, 2024
  • 9 replies
  • 303 views
In the attached file, we’ve created a simple singlet with (artificial) deformation FEA data for the front and back of the lens.  The FEA data includes a decenter of Y = 1 mm and a tilt about X of 3° for the lens as a whole.  Also, the higher-order deformations on the front of the lens convert the spherical front surface to an asphere,  to correct the spherical aberration in the system.  (Warning: It is not usually the case that deformations on an optic make the performance better!)
The singlet is shown below, and the FEA deformation data is displayed using the Multiphysics Data Viewer in STAR.
A singlet lens, and artificial FEA data that introduces a Y decenter of 1 mm and a Tilt About X of 3 degrees.
Next, we use the Multiphysics Data Loader to check that the FEA data is aligned to the front and back surfaces of the lens, and proceed to fit and load the deformations onto the lens surfaces.
Applying the FEA data to the singlet using the Multiphysics Data Loader.
After fitting, the Structural Data Summary shows the data that was applied to the surfaces.  The properties of each surface display informations about the rigid-body motions that are present in each FEA data set.
Viewing the RBMs on each surface using the Structural Data Summary.
https://community.zemax.com/star-module-user-group-85/rigid-body-motions-rbms-in-star-part-1-overview-5392
https://community.zemax.com/star-module-user-group-85/rigid-body-motions-rbms-in-star-part-2-a-simple-singlet-5393
https://community.zemax.com/star-module-user-group-85/rigid-body-motions-rbms-in-star-part-3-evaluate-performance-with-and-without-rbms-5395
https://community.zemax.com/star-module-user-group-85/rigid-body-motions-rbms-in-star-part-4-a-note-about-apertures-and-rbms-5396
https://community.zemax.com/star-module-user-group-85/rigid-body-motions-rbms-in-star-part-5-converting-rbms-to-coordinate-breaks-5397
https://community.zemax.com/star-module-user-group-85/rigid-body-motions-rbms-in-star-part-6-converting-the-new-optic-positions-to-nonsequential-mode-5399
https://community.zemax.com/star-module-user-group-85/reminder-use-the-multiphysics-data-loader-to-remove-fea-data-from-a-system-5398
Hi Erin,
This is fantastic. Can you clarify how the high order deformations ‘know’ how to correct the spherical? That implies a feedback loop.
  • Mark
  • 53 replies
  • October 15, 2024
Ah - no, it’s not that fancy.  I just manually calculated the dZ needed to convert the spherical surface into an asphere, and wrote it into my FEA data file.  Outside of the rigid-body motions, the only change to the surface shape is this dZ data; otherwise, dX and dY deformation vectors are 0.
  • 53 replies
  • October 15, 2024
I should have reminded everyone in the article that the deformation data format is just:
X Y Z dX dY dZ, for every point in the FEA data set.  We usually use about 10k points per inch of diameter or so.
Thanks! So how does the spherical get corrected? As you say, it’s unusual for deformations to improve the lens, so how is that happening physically?
  • Mark
  • 53 replies
  • October 15, 2024
I calculate the dZ deformation like this:  the lens starts out with a spherical front surface.  To correct the spherical aberration in the lens, I can optimize to find the aspheric terms needed on the front surface: rho^4, rho^6, rho^8, etc.  I calculate dZ = (sag of the asphere - sag of the sphere), and write the FEA data out.  When I apply the FEA data, then, to the original lens, it just adds a dZ shift to convert the sphere to the asphere that I want.  (It’s all very manual.)
The combined effect of the aspheric terms is to make the surface flatter as you move toward the edge of the part, compared to the sphere.  So where the sphere has constant curvature as a function of radial position, the deformed surface has a curvature that decreases as you move radially outward.
(But let me know if I misunderstood the question!)
I think it may be me who misunderstood. In your original post you said “Also, the higher-order deformations on the front of the lens convert the spherical front surface to an asphere,  to correct the spherical aberration in the system.” (My emphasis.) This implied to me some way in which the deformations ‘knew’ how to adjust themselves to produce a desired optical outcome.
I was thinking of something similar to tolerancing, in which we adjust the compensator to achieve best focus and can find a better spot than the nominal design, but this requires an adjuster and a measurement system capable of knowing what best focus is.
In this case, is the correction of spherical coincidental, rather than intentional?
  • M
Chris Normanshire
Hi @Mark.Nicholson I believe it is intentional. Erin has created an artificial sets of deformation & RBM data. For the purposes of this example, they were not generated by and FEA solver, but created by just writing the data out in the X Y Z dX dY dZ format. For the front face of the lens the data was manufactured by optimising an aspherical singlet to correct the spherical. The sag departure of the front face of the singlet from a sphere, with the same base radius of curvature, was extracted and written out in the STAR (X Y Z dX dY dZ) format. Hence, when these ‘deformations’ are added back to the spherical surface they have the effect of correcting the spherical aberration.
I’m a bit confused now. I thought it was coincidental that the deformations reduced the spherical, and there was no ‘invisible hand’ guiding the process.
Are you manufacturing the part deliberately ‘wrong’ and relying on the deformations to correct the surface shape, so that you get the correct sag in situ? Pre-distorting it so the deformations correct it? In that case, why is ‘It...not usually the case that deformations on an optic make the performance better!’
I think I’m getting hung up on why, if we’re looking at rigid body motion, the surface deforms at all. I’m sure I’m just being slow…
  • Mark
Chris Normanshire
Hi Mark. Sorry I missed your reply. In this example the ‘FEA’ data is manufactured and not intended to be realistic. The original lens has some residual aberration as can be seen in the spot diagram. The FEA data contains, as well as RBMs, some artificial deformations that effectively correct the residual aberrations.
This is definitely not what would happen in a real world scenario where the deformations are caused by external loads and stresses. However, the intention in this thread was to show the impact just RBMs can have on the optical performance. This can be seen where the RBMs add coma and astigmatism to an otherwise corrected lens.
I hope I’ve helped here and not confused things further.
