MODIFTSETTINGS type codes for geometric MTF
  • February 17, 2023
  • 5 replies
  • 214 views
harry000k
Type codes for modifysettings are listed in the Zemax help files under: The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > MODIFYSETTINGS (keywords)
However, Geometric MTF is not listed here. My question is: what are the type codes for the geometric MTF analysis window?
In case these do not exist, how would I go about modifying the settings for the geometric MTF analysis window via ZOSAPI?
Hi harry,
If those codes are not in available in MODIFYSETTINGS, I doubt you’ll be able to do it in ZPL.
The first thing to do to check how the settings of an analysis in the ZOS-API can be modified is to check the HasAnalysisSpecificSettings property. If you run the code below (Python):
# New Geometric MTF Analysis
geo_mtf = TheSystem.Analyses.New_GeometricMtf()
# Check if settings are implemented
if geo_mtf.HasAnalysisSpecificSettings:
    print('Geometric MTF has its settings implemented in the ZOS-API')
You should get the following result:
What this means is that the settings of Geometric MTF are directly available from the ZOS-API. You can find them in the ZOS-API Syntax Help (ZOSAPI.Analysis.Settings.Mtf.IAS_GeometricMtf Interface Reference):
Properties
IAS_Field  Field [get]
IAS_Wavelength  Wavelength [get]
SampleSizes  SampleSize [get, set]
bool  MultiplyByDiffractionLimit [get, set]
bool  ScatterRays [get, set]
bool  UseDashes [get, set]
bool  UsePolarization [get, set]
double  MaximumFrequency [get, set]
This is a small Python example for you:
# Get settings of analysis
geo_mtf_set = geo_mtf.GetSettings()
# Modify wield
field = 1
geo_mtf_set.Field.SetFieldNumber(field)
# Modify wavlenegth
wave = 1
geo_mtf_set.Wavelength.SetWavelengthNumber(wave)
# Modify sampling
sampling = ZOSAPI.Analysis.SampleSizes.S_32x32
geo_mtf_set.SampleSize = sampling
# Use polarization
geo_mtf_set.UsePolarization = True
# Apply settings
geo_mtf.ApplyAndWaitForCompletion()
  • 1115 replies
  • February 17, 2023
Hi harry,
Properties
# Modify wield
field = 1
# Modify wavlenegth
wave = 1
# Modify sampling
# Use polarization
# Apply settings
harry000k
  • Student
  • February 17, 2023
Hi David,
I tried running your code in the python interactive extension template and I am getting the following error:
AttributeError: 'IAS_' object has no attribute 'Field'
Thanks for your help,
Harry
  • 1115 replies
  • February 17, 2023
Hi Harry,
Strange, it works for me with Python 3.8.13, Pythonnet 2.5.2, and OpticStudio 23.1.
Can you check your version of Python and Pythonnet?
harry000k
  • Student
  • February 17, 2023
Hi David,
Yes you were right, I was running Python 3.9.2 with Pythonnet 3.0.1
I have now switched to a virtual environment running Python 3.8.10 with Pythonnet 2.5.2 and the code is working perfectly.
Harry
Gaia
  • December 24, 2024
Hi Harry,
Python 3.8 is no longer available, is there a way to modify MTF settings using the new versions of python?
Thank you,
Gaia
