Tilt and wedge tolerance
  • May 13, 2020
  • 292 views
Ian
  • 14 replies
I would like to request an improvement to tolerancing.  I always find it annoying that Zemax wants theta-x and theta-y for tilt and wedge when a drawing will have simply 'wedge' or parellelism of a spacer.  And wedge is usually quoted in arc minutes.  I would like to specify wedge (eg 0.5') and have Zemax randomly choose the orientation around the axis and then automatically define theta-x and theta-y which gives that wedge in that direction.  For backwards compatibility you could allow the choice of surface tilt or element wedge like you can choose S+A irregularity or Zernike irregularity.
You would have to define which surface needed to have the wedge error or course.
Hello Ian,
This is certainly a good idea. I think that it will improve the workflow.
I will add a feature request on your behalf and the product team will review it.
Sandrine
