Hi! I have a question about modeling a gold nanorods solution. This solution has a Molarity of 2.5 (nM) and a Molar extinction coefficient of 9.68*10^8 (M^(-1)cm^(-1)). The optical path is around 6.33 mm.
I am modeling in non-sequential mode. Following the guide on this post: https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01525, I tried to modify the material water within Zemax by changing the transmission.
The transmitted intensity is given by Beer's Law and is roughly 0.2. However, when I changed the transmission from 1 to 0.2 at the wavelength of 808 nm, the detected intensity does not change compared to the default water. Can anyone help with this issue? Should I change anything other settings to model the gold nanorods solution? Thank you so much!
