Wavelength range in Coating's Reflection vs Wavelength
  • January 6, 2025
  • 60 views
mocquin
In NSC mode, in Analyse/Polarization tab/Coatings/**any** vs. Wavelength : can you confirm that the range of accessible wavelength is determined by the min/max wavelength defined in the system explorer ?
Because with only a wavelength at 10µm, only data at 10µm is displayed on the Reflection/Transmission/etc graphs, even after modifiying the “Minimum Wave”/”Maximum Wave” in the settings of the graph.
The doc mentions (Reflection vs. Wavelength (coatings, polarization group)):
Min Wave The minimum wavelength to plot. This defines the left edge of the plot.
Max Wave The maximum wavelength to plot. This defines the right edge of the plot.
but does not precise that those values must be within the system explorer wavelength range.
Best answer by Sven.Stöttinger
can confirm this. I recall discovering this, too when I was looking at wavelength dependent reflections when only had a single system wavelength selected. The maximum range of wavelengths for this kind of analysis seems to be determined by your wavelength range defined by the system wavelengths.
Sven.Stöttinger
