Zemax operand values are different from the plot
  • November 4, 2024
  • 87 views
AliR
Dear all,
I have a question regarding a ZEMAX model of a segmented telescope, which I’ve set up using non-sequential components.
The issue arises with the DENC and GENC operands, which return incorrect values when I introduce disturbances to the segments. Specifically, the encircled energy value I observe in the plot differs from what GENC and DENC report after I apply any clocking or decentering adjustments to a segment. However, in the nominal model—where no disturbances are applied to the segments—the GENC and DENC values are accurate.
Be the first to reply!
