Zernike Fringe Phase and optical power
xavier_bth
I would like to create a surface that has a spherical and/or cylindrical power. I beleive I can use a Zernike Fringe Phase surface and enter Zernike coefficients to mimic the spherical and cylindrical powers by tuning Z4 / Z5 and Z6 (spherical power + both astigmatism coefficients). However when I play around with the value of Z4 and add some spherical aberration to my surface it does not add any power to my optical system. Is this behavior expcted? Which type of surface should I use instead that would creat optical power on my system based on the Zernike coefficients?
Best answer by Mark.Nicholson
I don’t recall what that is, but I’ll bet it’s 0. Try +/- 1
What value have you set for the diffraction order parameter?
xavier_bth
  • January 30, 2024
Dear Mark,
I haven’t touched this value and kept the default setting in Zemax.
