the software is taking the max cores available only in the first run and after that it takes nearly 30% of the max cores.
What should I do?
Thanks
What should I do?
Thanks
This ticket has been solved by the support, but just as a side note here are a few helpful comments from my colleague
“OpticStudio does attempt to use as many cores as possible up to its 64 core limit. However, optimization and raytracing can both be bottlenecked by a few factors:
