Can an asymmetric thermal effect be simulated in Zemax?
  • February 10, 2023
  • 97 views
Dear Members,
I am asking only to underswtnad if I can use Zemax for some Thermal lensing Simulation.
My principla question is the following:
I have a Lens in an holder of a certain Material (e-g- Aluminum). The Holder is heasted from a side by a thermal source which charachteristics I know.
Could Zemax simualte the change in optical performances for focussing a laser beam with the change of the temperature of the thermal source?
Thanks a lot
Best regards
Gabriele
Best answer by Andrey.Pravdivtsev
You need to calculate thermal distribution and how it influence on surfaces/elements in external software and use STAR module to check the performance with these thermal effects.
Thanks Andrey,
I have still to get the STAR Module but then your solution  should make the work.
Sorry for the delay of my reply I was a bit busy in these days.
Bests
Gabriele
