Hello again,
today I have a question about the NSDD operand, Pix#-10.
According to the documentation this should calculate x² which should be the 2nd order moment of the intensity distribution on the detector.
May I ask if the x-coordinate of the centroid is considered for the calculation of this parameter?
I also would like to know, if Pix#-10 provides the variance (which is from my point of view the 2nd order moment) or the standard deviation (which is from my understanding Sqrt(Var)).
It looks like Optic studio calculates the standard deviation instead of the variance.
And is variance / standard deviation calculated by integrating over the whole detector area (2-dimensional integral)?
Unfortunately I cannot find any formulas about this in the Optic Studio documentation.
Thus I would be very lucky if you can help bringing some light into the darkness…
Thanks for your help and best regards
Dirk
