Hi I have a question about the chromatic focal shift tool in Zemax
when using the tool with thorlabs plano convex lens LA1417 lens the ray diagram and focal shift tool match, where the focal displacement is -2.7mm between 800nm and 1500nm
but when using the tool with thorlabs achromat AC508-150-C the ray diagram and focal shift tool do not match where the ray diagram illustrates a shift of around +1.3mm and the focal shift tool illustrates a shift +450um?
Clearly the achromat is a thicker lens , is the cause of the difference between ray diagram and focal shift tool ? which method in this instance would be more accurate?
