I am setting up a polarising plate beam splitter to look at its different excitation at 780nm. I have defined a coating reflections and transmission in the table at 45 and 27.9(refracted angle). If i include scattering 0.01%, the NSC 3D layout stops showing the reflected beam from one surface whereas the shaded model shows it.
Also, the detector shows the maxima for rays which should have less power as opposed to main beam.
I have attached the model. Please check.
Another thing i wanted to ask was how can i include polarisation to the source. And specifically measure the power from individual beams at detector stop.
Saurabh
Hi Saurabh,
Thanks for your question here on the Community forums!
I have taken a look at your file and the difference between the 3D Layout and the Shaded Model was caused by the different Settings, i.e. Scattering was enabled only in the 3D Layout Settings, but not in the Shaded Model. Once Scattering is enabled, the Minimum Relative Ray Intensity has to be decreased under the System Explorer > Non-Sequential settings to make low-energy ray segments, such as those reflected from the front face of the splitter, visible in the System Viewer plots. For more details about coatings and scattering in NSC mode, please check out this knowledgebase article: How to add coatings and scattering functions to Non-Sequential objects – Knowledgebase (zemax.com)
Finally, you may define the Polarization of the beam under the Object Properties > Sources tab of the source object. Make sure to untick Random Polarization to enable the settings:
If you have any further questions, please ask!
Best, Csilla
Saurabh
Page 1 / 1
P.S: I have intentionally set the splitter coating on back surface.
Hi Saurabh,
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
