Designing a polygon mirror in OpticStudio
  • September 13, 2021
  • 5 replies
  • 408 views
Hi Everyone, How can I design a polygon mirror in OpticStudio? is there any library available to select the geometry of mirror and just insert the dimensions? thanks.
Best answer by Mark.Nicholson
You can use the Create Polygon Object tool in the NSC editor toolbar to create a polygonal mirror:
  • Mark
  • 909 replies
  • Mark
Thanks Mark for your useful response.
can I use this defined object in Sequential mode as well?
No, but you can use hybrid seq/nonseq mode to insert the part into an otherwise sequential system.
Thanks Mark for your quick response!
Marzanna
  • 28 replies
  • March 20, 2023
Hi Mark,
How this tutorial on polygon scanner in seq mode is different from the one in nonseq mode?
https://support.zemax.com/hc/en-us/articles/1500005576502-How-to-model-a-scanning-mirror
Marzanna
